Industrial UPS system. Suggestions please.
DanielWade
1
Hey, I am looking for a UPS system that can provide stabilized and filtered power for a vegetable extraction plant. According to the engineer, the required system should have input circuit breakers, maintenance bypass switch, bypass transformer, distribution breakers etc. Is there any UPS system suitable for this application? One of my friend suggested Staticon power backup systems. Is that good? I am looking for suggestions from experts in this industry. It will be great if it has more than 85% efficiency.
I suggest you move this question to a more appropriate forum as this one is about electronic power supply design - think power supplies for electronic products.
I recommend: forum238
Keith Cress
kcress -
Seems like the OP is asking about buying one, not designing one
So, the OP needs to do a websearch for "industrial ups" like:
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com:
It would probably help if you said where you're located. European brands are of little use in the US, and vice-versa.
there are some decent online selector tools available, just google around.
Important selection criteria that is often overlooked is the time required to start up the UPS. Some switch on in a fraction of a period, others are slower. Depends on your loads.
