I'm designing a small aluminum cam that will be turned with an allen wrench (or it could be a different cross-section). I'd like to have as small a socket as I can get away with--on the order of 5/32--for a given torque, without stripping the socket. I have vaguely heard of externally-splined steel allen-socket inserts that could be pressed into aluminum, but if they exist I haven't been able to find them or figure out what they would be called. If there is such a thing, what would you call it and where would you find it?
Thanks,
Drew
Thanks,
Drew
