Interference fit between a bin and a cylinder
franc11
New member
Jul 25, 2006
26
Hi all, I have here a little problem.
Is there any way to calculate the equivalent pressure on a pin caused by an interference fit with a cylinder?
Thanks.
My terminolgoy for you pin inside cylinder would be shaft inside hub. From Fielding's Handheld Caculator Programs for Rotating Equipment:
P = [<(delta*E )/ (2*rb*rc^2)> - <(3+nu)*w^2*rho/(8*g)>] * [rc^2-rb^2]
Symbols:
(1) ra = shaft id (often 0
(2) rb = shaft od and hub id (approx)
(3) rc = hub od
(4) delta = static interference
(5) E,nu - material properties
(6) w = angular speed.
(7) g = gravitation conversion
If w=0 (stationary), then this reduces to
P = [(delta*E )/ (2*rb*rc^2)] * [rc^2-rb^2]
Should have state something at the start. The pin and and cylinder are made with different materials.
I forgot to say that a, b, c are similar to ra, rb, rc above.
a = radius of inside of inner cylinder
b = raidus of outside of inner cylinder (same as inside of outer cylinder)
c = radius of outside of outer cyliner
A question, asked frequently.
Cheers
Greg Locock
Check out the forum at University of Tennessee, Martin. There is a website for Mechanical Engineering, the professor posted his notes on interference fits using Thick Wall Pressure Vessel Theory. Appended to the notes is a physical example of the application.
There have been past threads on this subject,as GregLocock correctly pointed out.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
