Hi, I’m new to pump field, so please help me.
I attached a drawing just in case I can’t explain myself clear enough.
Anyway, I read that ‘A relief valve is only needed if no other measures are provided to detect low flow conditions and shut down the centrifugal pump to prevent damage’, well in my situation, there isn’t a flow measuring instrument installed upstream of the pump, but there is a (tank) top mounted level transmitter to detect the level, I suppose if the level is too low, then there won’t be enough flow, so the LT can in a way detect the low flow condition, am I right? If not, does it mean I need a relief valve for this pump?
Thank you
Cutie
Thank you, EngTips
Thank you
Cutie
Thank you, EngTips
