Hello John,
Thank you for your help! I tried to use a split line on the model and got something very close to you. However, I was not able to convert the line surrounding the datum target area into the dashed line. Do you mind giving me further help? Thanks!
Hello John,
Thank you very much! The tips are helpful! However, my SW acts somehow weird. I followed your tips, but there is still a thin line surrounding the datum target area. I went back to the model and turned the sketch "Show" on and off. Then, the thin line disappeared, but the thin line appeared again after I save the drawing and reopened it. Do you have an idea to solve it? Thanks!
