VSEnergy
- Feb 20, 2012
- 3
Hi All, I am a fairly new grad currently working with a well reputed EPC (Engineering Procurement & Construction) company in the Oil&Gas sector in Calgary, Canada as a Mechanical EIT (Engineer in Training). I wanted to know the collective wisdom of the following career paths, from the experts who have done this before.
1. Is an MBA worth the time, money, and effort to eventually move up the ladder in the Energy and Processing industries? It seems that Engineers with field operations experience rather than an MBA are the ones who climb to the exec level of decision making roles in the EPC and Client side. Is Masters in Project Management even worth considering?
2. Is a general mechanical engineering Masters in Engineering (M.Eng, not M.Sc) worth considering in these sectors, to move up in ones career? It seems that most M.Eng degrees may be just degree mills which force you to take course which many not have much practical relevance to the particular industry, because of the intensive focus on theory. It seems that unless you are working with an OEM (Original equipment Manufactured), an engineer may not require the same level of detailed technical knowledge if you are working of EPC and Client side. Plus, I am not interested in R&D type career advancement.
3. My ultimate goal is to start a business in the energy or process industry, or to be in an exec position to make significant change/impact in the industry and to implement the latest R&D at a systems level. I feel that for this I will need the finance and marketing background an MBA provides, and the operational experience working on site provides. However, the need for M.Eng is not clear.
Please impart some wisdom, on which experience path I should take to accomplish my goals. Should I first get some site experience, and then get M.Eng, followed by a MBA? In the short term should I try to be a specialist in static or rotating equipment, or try to move into PE (Project Engineering/Management) or Project Controls route? I understand there will be/is a shortage of qualified technical people in North America soon; I would like to be prepared for this as well.
Awaiting all your thoughts. Thank you.
