I've had some troubles with the NC machining. The toolpath generated by proe is not correct. I mean some times then the tool finish a slice it pass throw the model to start the next slice so it tries to cut the part where it has a lot of material. The result is a broken mill and deformation in the part.
The verification does not detect it. I have to simulate every machining but some times I don't appreciate the details, for example squares. Proe didn't gave me any solution.
does any one has the same problem? have you any solution?
