Isolation Transparency in edit
innov
Industrial
Sep 9, 2005
36
0
0
When editing a part in the context of an assembly, all other parts change to the transparent state I set in "Options". However, if I Isolate several components and then edit a part, I cannot get the other pieces to change transparency. What's up with that? Thank you
SW2007, SP 3.1
Intel Core 2 @ 2.66Ghz
2 GB Ram
FireGL V7100
Thanks for your reply.
I am able to make the whole assembly transparent, which is not what I want. I want all parts except the one being edited to be transparent.
I have tried changing those settings. They do work while not isolating components, but as soon as I start isolating pieces, the setting seem to have no effect.
Thank you for your reply
