Issue With Render set in drafting(NX.9.0)
While Using render sets in NX 9.0 Drafting, NX response slowly.(Especially on Big Assemblies)
Example
1. Update views taking more time than normal.
2. Taking more time on Saving the part file.
3. Taking more time on switching between sheets.
But when I tried without render set I didn't find any of these above issues.
So kindly suggest any other way/options to resolve this problem/issue.
This question is probably to complex to solve without seeing the actual assembly.
There are so many factors that we do not know anything about.
Did you try with / without render sets on the same assembly, same drawing file ?
if nobody else has some tips , call GTAC.
Tomas
without render sets there is no lag in the same assembly/drawing file.
This issue arise only while using render sets.
