Hi all
I'm trying to create a spline model of a JIS D 2001 female spline.
Its 20 deg PA, 22tooth (1mod) side fit, 20.673 base dia, 22.0 mm pcd, 22.0 minor and 24.3 major dia. addendum modification 0.8
20.067/ 20.157 between dia 2 pins.
Ive drawn the involute form basics but the tooth width is massive, so i'm assuming i need to pull the involute intersection to the base circle down to match the 0.8 modification (ie run the intersection of the involute to the base dia minus 1.6?) but i'm not 100% sure.
I only really need a cad profile, so if anyone can help (or provide a wiring profile...
i'd be very grateful
cheers
cam
ref thread406-280069
cheers
cam
