job error
nodek
8
Can someone explain me this error?
The job input file "Teleskop01.inp" has been submitted for analysis.
Error in job Teleskop01: in keyword *SURFACE, file "Teleskop01.inp", line 91549: Unknown assembly node set _PICKEDSET264
Error in job Teleskop01: in keyword *SURFACE, file "Teleskop01.inp", line 91551: Unknown assembly node set _PICKEDSET266
Error in job Teleskop01: in keyword *SURFACE, file "Teleskop01.inp", line 91553: Unknown assembly node set _PICKEDSET268
Error in job Teleskop01: in keyword *SURFACE, file "Teleskop01.inp", line 91555: Unknown assembly node set _PICKEDSET270
Error in job Teleskop01: in keyword *SURFACE, file "Teleskop01.inp", line 91557: Unknown assembly node set _PICKEDSET272
Error in job Teleskop01: in keyword *SURFACE, file "Teleskop01.inp", line 91559: Unknown assembly node set _PICKEDSET274
Error in job Teleskop01: in keyword *SURFACE, file "Teleskop01.inp", line 91561: Unknown assembly node set _PICKEDSET276
Error in job Teleskop01: in keyword *SURFACE, file "Teleskop01.inp", line 91563: Unknown assembly node set _PICKEDSET278
Error in job Teleskop01: NODE SET ASSEMBLY__PICKEDSET264 HAS NOT BEEN DEFINED
Error in job Teleskop01: THERE IS NO DATA ASSOCIATED WITH *SURFACE, NAME=ASSEMBLY__PICKEDSET264_CNS_, TYPE=NODE. NODES OR NODE SETS ARE REQUIRED.
Job Teleskop01: Analysis Input File Processor aborted due to errors.
Error in job Teleskop01: Analysis Input File Processor exited with an error.
Job Teleskop01 aborted due to errors.
I really don't know what to change. Please help.
According to what one of the CAE professionals said, those errors are due to a lack of reference to nodes (or surfaces) at the assembly (or interaction) level. Abaqus creates an assembly-level node sets automatically (I don't know why) and sometimes it makes a mistake by creating something that isn't required. Problem is that this professional doesn't use Abaqus/CAE preprocessor and can't help me with removing those redundant entities. Does anyone here knows how to remove a node set using mentioned preprocessor?
I see this error from time to time and it is usually due to a constraint or boundary condition applied at a surface that no longer exists. This can happen when you update the geometry of your assembly and do not update your constraints.
