JONSWAP spectum S(w)
Giu.seppe
5
Hello to all. Sorry for my english, I'm an italian civil engineering student.
I have a question about the JONSWAP spectrum. We know that the JONSWAP spectrum, in terms of frequency, is:
S(f) = α g2 (2π)-4 f-5 exp {-1.25 (fm/f)4} γexp {-(f-fm)2/(2σ2fm2)}
Now I would like to write S in term of ω: f= ω/(2π). The first piece of S (f) becomes:
S(ω) = α g2 (2π)-4 f-5 [etc.]
= α g2 (2π)-4 [ω/(2π)]-5 [etc.]
= α g2 (2π)-4 ω-5 (2π)5 [etc.]
= α g2 (2π) ω-5 [etc.]
The problem is that in all the books (and also on Wikipedia) it is written:
S (ω) = α g2 ω-5 [etc.]
without the remaining 2π in my passages. What am I missing?
Thanks for your help!
So, where did you get your version? Since you're the anomaly... would you argue with MIT?
Nevertheless, since it's in frequency space, it's likely that the putative Fourier transform's form is different, and the pesky 2π is often floating around as a square root term in symmetrical FT's or only in one direction. The only thing you can be certain about with FT is FT-1[FT(f] = f, i.e., the 2π term resolves itself when taking the inverse FT of an FT'd function
TTFN (ta ta for now)
Thanks for your answer.
First of all in original Hasselmann paper (pag. 32). Other references:
[ul]
[li]BENASSAI, Introduction to coastal dynamics and shoreline protection, par. 2.2.3 (pag. 100)[/li]
[li]OCHI, Ocean waves, par. 2.3.5 (page 45)[/li]
[li]SORENSEN, Basic wave mechanics for coastal and ocean engineers, par. 6.3.3 (pag. 138)[/li]
[li]USACE, Shore protection manual, vol. 1 (pag. 3-43)[/li]
[/ul]
It seems that there is a mistake in the third line. The second line shows f^5 whereas the third line shows the substitution f=w/2n as(w/2n)^-5. the -5 exponent should be a positive exponent unless further substitution in the original equation shows that you are correct.
Note that Pierson-Moskowitz's original paper doesn't have a 2*pi term at all.
The bottom line is that if you can match the graphs, then you're done, regardless of the 2*pi
Sorry, I didn't understand. For more clarity, I write my passages
IRstuff said:
OP's first and second limes are incorrect; it should have f-5 as shown in the cited reference
Sorry, but (again) I didn't find the error you said...
