Kickers around vertical columns and RC walls
seankeith
1
Hi, referring to the attached picture, are kickers like these supposed to be cast together with the slab monolithically? Or it must be done under 2 castings?
Is preventing cement grout leakage one of the major reason we use kickers while casting columns/walls besides having proper alignment?
I have never used column 'kickers', but can see their usefulness. Yes, they would help in preventing honeycombing and assist in form alignment. I doubt good alignment would be achieved in most cases if you cast them monolithically with the slab.
