zdas04,
The comment “The role and relative importance of CO2 in producing these climate changes remains unclear” is the problem statement. This paper looks to help clarify that problem. They explain their method on how they attempt to do that in the very next sentence, “Here we construct a record…”. They find that “temperature is correlated with and generally
lags CO2 during the last deglaciation.”
“warming driven by increasing CO2 concentrations is an explanation for
much of the temperature change at the end of the most recent ice age”
Let’s look into the article to see if we can try and quantify “much”.
First, we’ll relook at the figure I present in the last post. In haste, I didn’t explain it very well at all, my mistake. The red line is the Antarctic temperature, the yellow dots are atmospheric CO2 concentrations and the blue line is the global temperature.
[image
Quotes from the paper:
“Our results indicate that CO2 probably leads global warming over the course of the deglaciation.”
“the small apparent lead of Antarctic temperature over CO2 in the ice-core records
does not apply to global temperature”
“An important exception is the onset of deglaciation, which features about
0.3 C of global warming before the initial increase in CO2.”
From the figure, The global temperatures went from -3.5 C to 0 C, a rise of 3.5 C. The author states that 0.3 C of that warming occurred before the increase in CO2, so 0.3/3.5 = 8.5%,
leaving 91.5% of the warming occurring after the CO2 rise. So, explain how I misrepresented the authors when I said:
rconnor said:
90% of the warming during the last glacial-interglacial transition (~20,000 years ago) occurred after the CO2 increase
The major problem is that you don’t know what the paper says, thought that you did (but got it wrong), and attempted to blame me for misunderstanding what the authors were saying. Shame on you.
Almost the entire argument surrounding the trope “CO2 lags behind warming” comes from the comparison between
Antarctic temperatures and atmospheric CO2. However, as illustrated in Shakun et al 2012, this does not tell the whole story or even the correct story. Antarctic temperature trends are very different than global temperature trends. Understanding the difference and relationship between the two is crucial (…but not for “skeptics” apparently). From discussion on variations in the Atlantic Meridional Overturning Circulation (AMOC), Shakun et al present a consistent physical description of the warming during the last glacial-interglacial transition and demonstrate that CO2 was most likely the main driver behind the warming.
They conclude with:
Shakun et al said:
Our global temperature stack and transient modelling point to CO2 as a key mechanism of global warming during the last deglaciation. Furthermore, our results support an interhemispheric seesawing of heat related to AMOC variability and suggest that these internal heat redistributions explain the lead of Antarctic temperature over CO2 while global temperature was in phase with or slightly lagged CO2.
