nuuvox000
- Sep 17, 2019
- 344
I've just read through the ASHRAE laboratory design guide but I'm still a little confused about pressurization techniques for laboratories. I have two fume hoods which will exhaust air so I believe I need to supply makeup air while they are running. But I also need to keep the laboratory space at a negative pressure with respect to surrounding spaces. The dilemma as I see it is that I will have to introduce makeup air for the exhaust hoods but this means I still need to have general exhaust to keep the space negative. But if I keep the space negative, don't I risk pulling fumes out of the exhaust hoods?
My other question is on air leakage area (sq in/100 sqft). Have any of you had experience using certain values? ASHRAE says it can vary from about 2 to 30 sq in per 100 sqft of surface area. Based on the study they referenced, I'm using about 20 (non-gasketed ceiling tiles, one door, two windows, 155 sq ft room).
I'm just starting out so thanks for your patience. Thanks in advance!
