The project has a large rectangular tank 47 ft X 19 ft with 11 ft high walls that are 15" thick. It also has pilasters every 7ft that are approx 2'-3" wide. the water slurry level is approx. 10 ft. the tank was built in 1983. We need to install a 20" dia pipe near the bottom of the side wall between the pilasters. We plan to core a 24" dia hole approx 2'-9" above the floor. The wall has #8@12 vertical and #6@12 horizontal that we will cut through. The dowels from the footing will also be cut because of the location of the hole. I am not sure how to address the removal of the bar in the existing wall and so close to the bottom. Any thoughts would be appreciated?
