Hey guys,
I'm designing a stand alone structure that supports a fall arrest system. It's inside a tractor trailer factory where workers walk atop tankers to perform maintenance. The company needs trolley beams overhead two adjacent bays that the workers can connect to for fall arrest. Top of steel for the trolley beam is about 20' above the floor slab so columns are relatively tall. I'm using a factored vertical arresting load of 16 kN (3.6kip) for design. I'm wondering what kind of lateral loads I should be designing the structure to resist? I'm thinking the lateral load could be caused by the pendulum effect if a worker were to fall from a point where the fall arrest connection isn't directly overhead. I'm currently thinking of taking the horizontal component of the fall arrest load if the worker is swinging with a landyard that's 45 degrees from vertical. This would be about 11.3 kN (2.5 kip). Curious to get others opinions on the magnitude of this design load.
