For what it's worth, I just did a bit more research.
drwebb's comments are pretty well on the mark
Brominated and/or chlorinated hydrocarbons are added to leaded fuels as lead scavangers to convert the lead deposites to volatile lead halide salts, so as to avoid excessive build up of lead.
The level that these are added at is critical. To much, and you get corrosion, to little and you get fouling.
Avgas specifies the chemically correct ratio, while automotive gas normally has a little more.
Once again, one of the advantages of leaded fuel was that the deposites lubricated some components, so for this to work, the lead scavangers must be in the correct proportion to leave a little lead behind.
The light grey or white deposites on the tailpipe of a correctly tuned car running leaded fuel are probably these lead halide salts. They will deposite where the temperature of the tail pipe surface is low enough for them to solidify on contact.
See the link in my post of 06/11/03 for details
Back to reality again.
The only engines I ever saw corrosion problems on were boat engines which operated in a salt water environment, or engines that were left exposed to the weather and not used for years. I am sure that the corrosion in these cases is down to the salt and long term exposure to water, and occurs no mater what fuel is used.
The only cars I ever saw with premature corrosion of the exhaust system, were those production road cars that had a design that retained water (like the loop over the back axle), and where the manner of use never evaporated the water out of the system. In my experience, racing use blows and boils all water out of the tailpipe and muffler.
I don't see any of these problems with this guys motor bike
pat
