billeeee
- Feb 22, 2016
- 7
Hi All, I am designing a large diameter (>2400mm) slip-on plate flange connecting two parts of a vessel using the Taylor Forge method. The vessel is 10mm thick and in order to come out with a reasonable flange thickness I have thickened up the shell at the connection with the flange. Question is, how long does this thickened up section need to be before I can taper back down to the main vessel thickness? There doesn't seem to be any code limit.
