SylvestreW
- Apr 11, 2005
- 203
Afternoon all,
I'm looking for some published data on what levels of vibration would start to cause someone to detect it audibly.
I've found this link: with a graph on pg. 7 by T. Mikawa but I was wondering if there's any newer research.
What I'm trying to determine is:
A piece of equipment is causing vibrations at a house some distance away. I've measured the spectrum at the machine and at the house and the profile's identical (but reduced at the house obviously).
In my particular situation, the machine has a operating freq. of 45Hz and harmonics are clear up to 3rd (135Hz). Looking at the graph above, at the house I'm measuring a vibration level of 51.9 dB (re: 39.4e-8 in/s) at 135Hz however when measuring the noise, it's clearly! audible in the room.
The background in the room at 125Hz (closest freq.) is ~35 dB (re: 20uPa) and when the machine is on, I'm measuring ~45dB.
According to the graph in the link, I should be well below vibration and acoustic detectibility however that's not the case. You can't feel the vibrations but it's audible. I'm trying to determine if the vibrations are audible directly, or, since it's a residential house so there may be a loud-speaker effect from the drywall in the basement or something similar.
Thoughts?
Thoughts?
