Limit movement of a node 1
GeorgeEllwood
134
I'm wondering if it is possible to limit the movement of a node in ANSYS APDL? Without resorting to contact analysis or subroutines.
I'm working on a problem where the component I'm will be displaced, in real life once it reaches a certain point it will come into contact with another component which will limit it's motion.
Is there a way to include this as a boundary condition? This is analagous to a pin moving in a slot.
I.e. say the node is in position (0,0,0) and it moves only in the x direction. Is there a way I can tell ANSYS to allow the node to move freely in x until it reaches say (1,0,0) and then to tell ANSYS not to allow it to go any further?
I can restrict the movement in the y and z directions using the D command. I'm not sure if there any MPC commands that could be used for a constraint equation. One of the problems could be ANSYS would have to know in real time the position of the node without post processing, which could suggest using a subroutine. However I've not managed to get ANSYS working with a subroutine as yet and was wondering if there is a different way to do it?
Any help would be greatly appreciated.
George
Hi George,
I would take a look at the MPC184 joint elements in the Ansys Manual. The elements can also have some movement limits defined.
MESHPARTS
Tuning Your Simulation
Thanks Meshparts, I'd seen that the MPC184 elements could set stops or locks on movement. I'll have a think about how they could be implemented in my routine.
