Line weight in drafting
Do you want to change an individual line (select the line and you should see options in the ribbon at top of screen) or permanently change all the lines of a line style (format, style, select line in the top left box and away you go)?
In SE ST2 in the view tab click on styles and there you have a pulldown menu where you can select line and then you can edit the width of each line type.
If you have V20 or below look for the menu format if I remember right.
Hope it helps.
Patrick
