We are using liquid ring vacuum pump to create vacuum in few reactor. In order to reduce the water consumption, we recycle the water. The problem we have is that solvent, beiong soluble in water, accumulate in the water. This can build up to 40%.
I was wondering if there was any way of replacing water by another liquid for which the solubilty of solvent will be very low.
I heard about using H2SO4 (no corrrosion if concentrate) but we will have water coming from the reactors, therefor it will turn into a very corrosive solution.
Does any one got a solution? We don't want to change to dry vacuum pump (cost).
