I am sizing relief valves for liquid system for the first time. I usually work with natural gas. I know the code/standard and the equations and I can calculate orifice sizes.
However, I do have a question regarding blocked outlet on a pump. The facility is a pump station with 18 inch pipelines and 144000 barrels per day. My questions are:
1. For blocked flow at pump discharge, do I size using the entire 144000 bpd?
2. If so, the valve size comes out to a 4 by 6 valve. This seems quite large to me and larger than what I have recalled seeing at other pump stations.
Am I right in using the entire full flow for the calculation? If not, what flow should I use?
I will appreciate if anyone who has experience in this is able to help me out.
Thanks,
Berenger.
Thanks,
Berenger.
