loading stp file issue
Ehaviv
Computer
IL
Hi
When opening a stp file the procedure is
Load each component and save it.
Is it possible in some wsy to change that.
because it can be a long time to load
for large assembly.
Thank you.
Have you tried the external batch translators?
you have to setup Java manually to use them
Goto
Start -> Siemens NX 11 ->Step 203 or step 214
Thank you robnewcomb
How I set Java manually.
