Hi. I simulated an oil field with 3 well in pipesim. the wells are low pressure wells. anyone know how can i find the best location for the pumps? (consuming that the reservoir Specification like GOR is changing with time)
Mostly a hit and miss solution. (Design by experts, minimises the misses.) You start with somewhere at the centroid of all the well locations based on trying to minimise the costs of well_flowrates X pipeline_distance table to the CPF. Do the same for water supply if you need water injection.
