NickParker
- Sep 1, 2017
- 441
What is the difference between the locked rotor time tRE Vs tE? as tRE is mentioned as 35s and tE is 8s in the motor datasheet.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
RRaghunath said:tRE is when the speed sensor confirms that the motor is picking up speed (having been started) and thus has some cooling through the shaft mounted fan.
tE is when motor shaft is stalled, could be either stall during start or stall during run and thus has no cooling.
