Loft using non-planar, not closed curves 1
ACarrier
22
Catia V5 R20
I am trying to create a surface using non-planar and not closed curves, as seen in the attached file.
I need to know
1. how to close the curves,
2. make the curves planar in such a way as to not greatly affect the design OR
3. how to create a surface in the same spot, a surface that is tangent to the surrounding surfaces.
 http://files.engineering.com/getfile.aspx?folder=176c6cb7-1cd2-45d3-8157-278357fceb83&file=Pic.png
try the same function but in GSD not in partdesign
Eric N.
please use the upload image function to bring picture in your post.
Eric N.
itsmyjob
It all worked. The first time I did not select what surfaces to be tangent to. Now everything is perfect.
Arigatōgozaimash! Hai meiyo!
