Lofting hollow sections
EngJW
682
Is it true that you cannot loft something like a tube cross section into another one? You have to make a solid tube first and then use cut-loft to cut out the inside. If so, is there an easier way to do this? Hopefully I'm wrong as this would be a nice feature for making ports and variable cross section tubes. Thanks.
The Loft feature can be "Thin" Option should be at the bottom of the property dialogue.
If your parts thickness is uniform, I would model it solid, then shell it.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP3.0 on WinXP SP2
