Looking at the association of parameters by VBA
USB Memory
44
Hi all
Is there any way to just look at the each association
between parameters in CATIA and ones in Excel by VBA?
Parameters mean userparameters I defined
thanks
Thank you for your kindness.
I checked the macro script but it is only used to links an excel table with a design table.
I want to see the each association which are already linked like perameter "D1" in CATIA linked "D" in Excel.
thanks
yes, but that was just an example... showing the interface--explore the possibilities (if any) of the designtable syntax...
regards,
LWolf
Thank you, Wolf
the script is a good stepping stone and I'm serching into objects for the association.
but I haven't found the one yet.
Thank you for your new information.
I just checked the script on my enviroment.
but I think the script can wark as making DesignTable and add association dimension with parameters.
It's still difficult to see the association between parameters in CATIA and ones in Excel.
Specifically, I want to see the accosiation bellow picture by VBA
Thank you for answer.
I don't need to open the window like the picture.
I just want to watch the association through some properties.
(A is associated with A, B is associated with B)
As far as searching, there is no properties which have the association(excel parameter name).
thanks
I got what you want, and I was refering to the original thread request. Same answer - not possible in Automation. Look for non-programming workarounds.
Thank you Little.
I will give up on that.
The reason why I wanted to take the association is automatic control of parameters.
For the reason, I'll find another way without using the association.
thanks
