LunaPark
- Sep 26, 2019
- 12
This question has probably been discussed but I still have no idea what the practical and effective way to evaluate the loading on transfer beams or slabs is.
I have a building that contains multiple transfer floors that many transfer beams / slabs have been used. Using the tributary area method to envelope the elastic results from 3D models sounds time consuming. Also, treating the transfer member as support and use tributary area method will overestimate the loading on transfer beams / slabs way too much and lead to a over-sized transfer beams / slabs considering the deflection limit for transfer members is restrict too.
And if the elastic results are not reliable for transfer members design, so are other non-transfer members design as the load re-distribution because of cracking will affect them all, which means we are gonna envelope these two method for all members design?
So I am wondering how do you design structure when transfer members are involved? Does changing the stiffness to consider crack sound like a good idea?
Much appreciated if anyone could share his/her opinions, experience or any books regarding this.
