Looking for monitor recommendations
toycept
294
I've been using a CRT monitor for a number of years and am looking to change to a flat screen to use with SW. I'm asking if people can make some recommendations that you are happy with. Thanks!
I have dual HP Pavilion monitors, one 22" and one 24". Love them both.
Out of curiosity, how old is your monitor?
Jeff Mirisola, CSWE
My Blog
Hi Jeff, I've been using a Viewsonic which has to be more than 10 years old now.
With the combination of my eyesight waining and the quality of the monitor, I've got
to make a change. Since I posted this top last evening I've been reading good things
about the Dell Ultrasharp 2412.
I know I posted this info some where either here or at Solidworks Forum, however I am unable to find it.
I did some research for myself a couple of years ago and below is what I found to be the best way to consider buying a new monitor(s).
*LCD monitors types:
TN (Twisted nematic) - Usually these are the cheap monitors which turn out to be not such a good choice.
VA (Vertical alignment) - Medium priced, good but with deep blacks
IPS (In-plane switching) - Usually more expensive, but at a responsible price,quality a lot better than the two above
PLS (Plane-line switching) - New type of technology, has higher brightness with lower power consumption.
*Always go with LED backlighting.
*Response time is unimportant because anything lower than 12ms our eyes cannot track it.
*Recommended resolution recommended 1920 x 1080
Here is the link I got most of this information from:
Scott Baugh, CSWP [pc2]
Gryphon Environmental
"If it's not broke, Don't fix it!"
faq731-376
Dell Ultrasharp's are worth the money. I have a several of them.
We're running twin Samsungs for the last 5 years. 23.6" Diag. S24B300EL Samsung® LED LCD 5ms.1920x1080NR Mega DCR-DVI D-Sub-Eco Saving
Nice setup.
Be sure to get a 16:9 minimum aspect ratio, preferably 16:10. Those extra pixels in the y direction are nice with CAD software.
The Dell UltraSharp's are nice. IPS displays at 16:10 aspect ratios. All our engineers have dual 24", 16:10, Dell UltraSharps.
Anna Wood
SW2014 SP2, Windows 7 x64
I've used dual monitors, both 4:3 and 16:9, and even one of each, and I was always annoyed by the 'bar' between the monitors, which seemed to be always exactly where I didn't want it. I haven't tried it, but I think a single 27" or larger (with many pixels of course) would be better than two smaller monitors.
For the last part of my tenure with SW, back in 2010, I had IT remove all the corporate crapware from my SW computer and put it on an older surplus machine, so I had two computers and three monitors on my desk.
Mike Halloran
Pembroke Pines, FL, USA
thanks all for the suggestions. I'm leaning towards the Dell Ultrasharp 24 inch. I think
a 27 inch would be a bit big on my desktop. Too bad I couldn't try a 27 inch.. kind of take it for
a test ride. At any rate, at this point, anything a bit more "modern" than what I have would be
good. Thanks again.
I've been using a Dell S2340M, 23" Widescreen, LED Backlight, LCD monitor for a year now, and I love it.
Thaidavid
