Looking to Use Steel Beam in Residential application
Apexpredetor
52
Morning All,
I am looking to use a steel beam in a residential application. Trying to open up basement, but I am not too familiar with construction techniques to be able to specify the connections. ANy good references that might point me in the right direction?
I am a NY PE, not a home owner. I can probably brute force method design a beam, column, and footers, but any quick tips or references will be much appreciated.
yeah, but would you like the welds to be carrying the maximum load in this beam ?
i'd use nested splice angles (nest into the corner of the I-beam), a web splice, and a "boatload of bolts"
Quando Omni Flunkus Moritati
I'd be tempted to put them at 1/4 L of the ends (or 8' from one end), but a good weldment should be able to take full moment load.
lots of portal cranes/bridges are built up from more than one member, all butt welded together. I don't worry if 100% Rx (or UT) is performed.
but I would hate to pay for that, I forgot to mention.
YEs. Sorry for teh confusion. I didn't intend to splict the beam, rather I wanted to know if anything special was needed to join them at the column supporting the ends of each. I was assuming some sort of splice plate to keep them together longitudinally, but nothing that will be considered a gusset or full tension splice member since there would be a column supporting the ends, adn lateral support from Joists.
