Loop through assembly. NX Open C++
yadvdinesh
Aerospace
Apr 13, 2015
31
Can someone plz tell me whey the loop in the below code is not getting terminated? Its going in an infinite loop.
Session *theSession = Session::GetSession();
Part *workPart(theSession->Parts()->Work());
UI *theUI = UI::GetUI();
ListingWindow *list=theSession->ListingWindow();
NXObject *nullNXObject(NULL);
list->SelectDevice(NXOpen::ListingWindow::DeviceTypeWindow, "log.txt");
list->Open();
NXOpen::Assemblies::ComponentAssembly *rootAssembly = workPart->ComponentAssembly();
NXOpen::Assemblies::Component *rootComponent = rootAssembly->RootComponent();
vector<NXOpen::Assemblies::Component *> childComponents = rootComponent->GetChildren();
vector<NXOpen::Assemblies::Component *>::iterator itrComponent = childComponents.begin();
for(itrComponent = childComponents.begin() ; itrComponent != childComponents.end(); itrComponent++){
list->WriteLine("inside loop");
list->WriteLine("After the loop");
list->Close();
/* Terminate the API environment */
UF_CALL(UF_terminate());
Is the iterator stepping through the components?
Is ++ implemented for NXOpen::Assemblies::Component?
What do you see if you add the component name to the list->WriteLine("inside loop");? Is it stepping through the components?
Paul
Paul Turner
CAD & Process Engineer
Mastip Technology
I have found the solution Paul. The code written by me is correct. The problem was, I was using VS2012 for developing NX application & I was testing it in NX7.5. Whereas, I should have used VS2008 for NX7.5 applications. So, when I used the same code in VS2008 & created the dll, it worked perfectly fine in NX7.5.
