StephenArcher
I'm new to vibration analysis and I'm interested in measuring the dynamics of a rail vehicle.
I'm proposing to use a fibre optic gyroscope to measure roll acceleration (of approx 1 hz), but I need to be able to calculate roll displacement. I understand the usual method is to integrate acceleration using fft, however the time resolution of the fft will be poor because of the large window needed for low frequencies. This will cause problems as the roll acceleration may change significantly over the fft window.
Can anyone suggest other methods to do this kind of analysis. I'm looking into Charge Amplifiers with built in integrators such as the Bruel & Kjaer 2635.
Any help is appreciated.
