treetotreef
Automotive
I've purchased a nice new toy with a 4.2 V8, 11.6:1 compression and Prins LPG kit fitted.
As i understand it, these LPG kits take signals from the standard injectors and use that to trigger the lpg injectors (which are controlled from the fuelling maps in the LPG ECU), but don't modify the ignition maps.So even if the Standard ECU has self learning capibility, it's altering the wrong map...
In the interest of fuel consumption rather than max power output, how much scope is there for improvement with ignition advance(assuming that pump LPG is ~110RON)?
Please feel free to correct me if my understanding is wrong...!
