PEHasan
- Jun 21, 2005
- 52
What is the code/standard that is followed for the manufacture of Long Weld Neck Raised Face (LWNRF) flanges?
The following dimensions of LWNRF flanges are as per ASME / ANSI B16.5 standard: -
- Diameter of flange
- Thickness of flange
- Raised face of flange
- Diameter of bolt circle
- Diameter of bolt holes
- Number of bolts
Neck thickness or bore of Weld Neck Raised Face (WNRF) flanges matches with the pipe schedule, which conforms to ASME B36.10 standard.
To what standard does neck thickness and bore of Long Weld Neck Raised Face (LWNRF) flanges conform to?
- Number of bolts
