Vyacad
- Sep 10, 2014
- 14
Hello evreyone.
I´m trying to start a little customize in NX.
I need to create a macro with the following instructions:
I want to change some dashed lines so they are white and dashed just after I select these dashed lines.
Once I start recording the macro, I do the following steps:
1) View Dependent Edit
2) I select the view
3) Edit entire Objects
4) Line color>White
5) Line Style> Dashed
6) Line Widht>0.13mm
7) APPLY
8) Selection Filter>Curve
From step 2 (view selection) I would like the curve selection window to appear but the macro stops at step 3.
What am I doing wrong?
Thanks!
4) Line color>White
7) APPLY
Thanks!
