MACRO PART NUMBER WILL BE THE SAME AS INSTANCE NAME, HELP
bambambidam
17
hi all,
i would like to create a macro that will change part number and will be the same as instance name.
because when i'm exporting catia product to 3dxml file it copies both partnumber and instance name in the specification tree, I only need to show instance name.
thank you and regards,
yep that would work, I've done it.
[ul]
[li]you need to go with recursive script[/li]
[li]you should avoid instance with same name in a product level, as the script should not take long to run, you can think about using 2 passes, first one with dummy name or dummy number to clean everything then second pass would make it good.[/li]
[li]you can use object Dictionary to easily keep track of number of instance of a partnumber.[/li]
[/ul]
post your progress I'll help
Eric N.
Hi
You can try also something else, results may be different
Fernando
- Romania
- EU
hi thanks for the replies. but can i also just delete the instance name and how?
or i have an idea just delete the part name and leave the instance name
