magnetise a cranksharft
brettau
Automotive
Sep 6, 2015
1
Hello to all I am a total novice in this field. I have a small 100cc 2 piece crankshaft that weighs nearly 4kgs. when the crankshaft is put together the middle of the crankshaft is a 10mm gap between crank 1/2s for a 6mm conrod hope you got that bit.ok if you magnetised the whole crankshaft plus conrod in three parts or maybe not the conrod I don't know. my interest in this is if the crankshaft is spinning at 14000rpm with 2mm gaps between metal is there any benefit and the magnetic field what's happing. the crankshaft is from a Yamaha kt100s kart motor if you look at the specs it will give you a lot better idea of what I am looking at. Cheers Brett
The Yamaha factory service manual for your KT100S engine shows for an assembled crank there should be a gap of 2.70-3.05mm between the rod face and crank face with the rod pushed to one side. It appears your S model is different from other KT100 models (J, SC, etc) in this regard. The other KT100 models use a washer on both sides of the conrod, and so the gap is much smaller (<1.0mm). You should also make sure the measurement between the crank main journal thrust faces is within 45.8-45.9mm.
I don't understand your question about "magnetic fields" in the rotating crank assembly.
You want the magnetization to help keep the conrod centered on its journal?
2 stroke engines with "piston guided" con rods usually have huge big end side clearance.
I'd be some concerned that ferrous debris might choose to hang around a magnetized crank assembly.
As far as power boosts from the interaction of the magnetic forces, that would fall under the category of perpetual motion, or something close to it.
