making a helical half sphere ? 2
FXjohn
Automotive
Mar 17, 2007
82
0
0
I'm trying to make a design out of helical wrapped wire that makes a cylinder and the ends in a half sphere. I;m not sure how to apply the law curve function to do that. NX 7.5
see attached picture and UG file
thanks
Hi NXHerbie,
To add to the last turn change the PitchAngle expression to be 90/(floor(turns)+1). Then you can set turns to say 10.5 etc. There will still be a limit to get a valid tube in the last turn.
Frank Swinkels
Stephlouv's approach results in an uniform radial pitch when viewed from the top of the dome.
Frank's approach results in a uniform spacing along the face of the sphere.
Attached is a third approach approach that results in a constant pitch along the z axis and controls the helix radius with a set of law curves.
 http://files.engineering.com/getfile.aspx?folder=6a26603f-89ba-45ab-b225-0ad1b5abc7d0&file=sherical_helix.prt
