Manhole Gaskets Standards
batman77
3
I'm new to this forum / topic.
Can someone guide me to where I can find standard dimensions for oval/obround gaskets.
I have this gasket spec and would like to understand what the dimensions are.
Spiral wound gasket, KRAJ Type KRS Gasket 465 x 427 / 420 x 382 x 4.5 thickness.
THANK you.
ASME B16.20 "Metallic Gaskets for Pipe Flanges: Ring-Joint, Spiral-Wound, and Jacketed"
ASME B16.21 "Nonmetallic Flat Gaskets for Pipe Flanges"
It looks your oval spiral wound gasket dimensions is specified as outside LG x inside LG on both long and short directions. So, the width of the gasket is 38(mm?).
