Master Model Style Attributes in Drafting fail using "New Sheet" creation method
3dr
Automotive
Jul 10, 2004
456
I've been successfully making drafting files using the Maser Model "File New" "Drawings" Tab.
(Attributes populate correctly etc...)
I've recently rehabbed my methods and now have attributes to populate using the "New Sheet" "Use Template" method. (For making sheet 2,3 etc...)
This consistently fails to populate the attributes.
An Error Message says "Data within These cells has been deleted but the text retained"
It's not the Templates issue. They all work when using "New File"
They all fail when using the "New Sheet" method.
It appears you can't populate data fields using attributes when creating a "New Sheet"???
Does anybody know what is going here because that just doesn't seem right.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX11, Win 10 Pro
We do it all the time...have you verified that nxdm_ugs_sheet_templates.pax or ugs_sheet_templates.pax are pointing to the correct drawing format files? I've had them "break" due to a revision change.
-Dave
NX 11, Teamcenter 11
No, they are pointing to the right files.
I've even re-pointed them to other source files to test their behavior.
The same failures resulted.
Dave
NX11, Win 10 Pro
