NRP99, I don't understand your point. When I read your points from a theoretical average life point of view it makes some sense. However we are not discussing theory and average life. I am referring to the real world safe operation and its associated U-Stamp certification requirements.
NRP99 said:
What GD2 said is correct. The margin on creep rupture stress for 100,000hr life will ensure that the stresses in the component undergoing creep will not go beyond creep rupture stress for 100,000hr life and in the process, conservatively, we have extended creep life by using that margin (less stress than creep rupture stress means higher life). See ASME B31.3-Appendix V for simple example considering creep damage of 1 with case of normal operation period and temperature excursion period.
You correctly initially refer to the safe operation of a "single item" of equipment with the F factor applied. However in the second part of your statement you incorrectly mix up a single component with a statistical sample of components. You can not extend the creep life by using the F factor because if you increase F even slightly then a small percentage of identical items of equipment coming off the production line will fail before they reach 100,000 hours. If you increase F to 1.0, then 50% of items of equipment coming off a production line will fail before 100,000 hours. How do you know if the "single item" of equipment you refer to at the beginning of your comment will survive 100,000 hours with an increased F value? The answer is you don't know, therefore applying the F value doesn't increase the creep life. This is a real world Engineering Forum. We are not discussing theoretical average life science.
The ASME B31.3-Appendix V calculation has the F factor at its core and will therefore reveal a maximum allowable life of 100,000 hours for an item of U-Stamped equipment designed to utilise all of its material thickness. The only way to extend the life of this equipment beyond 100,000 hours into the statistically dangerous failure region while complying with the law, is to conduct periodic physical tests and measurements in accordance with ASME FFS-1.
Where the design of an item of U-Stmamped equipment has excess shell thickness, at 100,000 hours the user is required to conduct a life extension assessment. To claim at this point that the F factor extends the life and therefore do nothing is misleading and dangerous. The actual operating stress can be can be multiplied by F=0.67 and then a life can be calculated using ASME FFS-1 or perhaps ASME B31.3-Appendix V. Because the F factor is applied to the stress, this extended life to perhaps 200,000 hours does not extend into the statistically dangerous failure region. After 200,000 hours, the only way to extend the life of this equipment while complying with the law, is to conduct periodic physical tests and measurements in accordance with ASME FFS-1.
jtseng123,
I assume your equipment has excess thickness which you utilise at the 100,000 hour mark to calculate an extension of the life of your equipment to 25 years? Perhaps you have added extra thickness and calculated a life of 25 years using ASME FFS-1 at the design stage before fabrication. Or perhaps you are conducting periodic inspections and measurements to predict the failure life? If you are just winging it after 100,000 hours without any life calc or inspections, then that doesn't sound right.
We had a failed Hydrogen reformer tube about five years ago. The Engineer responsible was hauled in front of the Chartered Engineering Tribunal to demonstrate that he did everything by the book. It was the worst day of his life, and thankfully the Tribunal cleared him. Our team in the US, doesn't keep a paper trail to protect themselves.....
