struclearner
- May 8, 2010
- 122
Dears,
Is there a way to model a material with different Modulus of Elasticity (E) in tension and compression.
Anisotropic material properties gives the option of defining different E values in different directions.
How the different E values in Tension and compression can be defined for analysis of the materials having different properties/response in tension and compression.
Thanks for the input/help.
