Material properties 3
wgr4895
5
Could anyone fowarder me a material properties like ultimate strength,yield strength, thermal coefficient etc for this material :
1. "COrten steel"
2. Rockwool
COR-TEN is a tradename used by U.S. Steel for a group of HSLA structural steels. You can find information on these grades, including mechanical properties, at the following website:
The coefficient of thermal expansion depends on temperature, and to some extent on alloying content. The following data is for a C-Mn-Si steel, which is what COR-TEN is:
CTE Temperature
(in micrometers/m C) (in degrees C)
9.5 25
11.5 100
13.5 200
15.0 300
16.0 400
16.4 500
16.6 600
Note that this data is not averaged. IF you want an averaged number, then something like the following values would be more appropriate
AVG CTE
10.2 from 20-100 C
13.5 from 20-400 C
14.4 from 20-600 C
As for Rockwool, I am not familiar with this name. You may try the following website for info:
Rockwool is a trade name for a type of mineral fibre insulation made by, would you believe, Rockwool. Their main site is very comprehensive and should contain most of the info you are looking for.
Ed
properties of rockwool
thermal properties
and insulation information
regards
