Hi
When using abaqus to check if an element is failing in shear what's the check that you need to carry out as I am assuming that the program will not tell you it is failing?
I am trying to find the maximum load on a single bolt single shear assembly in a brittle material.
Many thanks
AM
Many thanks
AM
