Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Question: May the tensile strength recorded on a Material Test Report be used to calculate the wall thickness of a pressure vessel?
Reply: No.
The original question was about ASME and you replied with an AS 1210 point of view. ASME and AS are two different standards. You can't compare apples to kiwis. : ))I am talking about Australia, where the U-stamp doesn't have much significance, since a recognised authority has to confirm independently that the design is safe and in accordance with the basic safety requirements outlined in AS 1210 and the local fguvernment eregulations. In my opinion, that is the real engineering of a pressure vessel, rather than follow blindly the code, including the mistakes, misprint or other errors of the code.
