buzzedge
Automotive
- Feb 10, 2022
- 11
Hi guys,
We're looking improve a small oem shaft/gear combo that has seen failures in one specific spot. It's a small shaft 13mm in diameter which has a 90 degree reduction down to 8mm. It has a gear, ~38mm diameter, at the other end of the 13mm section. We're not quite sure what kind of loads the shaft sees, the failures are somewhat rare but still we want to make an improvement. The failures have been where the 8mm section meets 13mm section. We can't modify the shaft dimensions in any way, the 90 degree reduction must stay.
We want to have a one piece billet shaft made but unsure of what material to use so the shaft itself is stronger without compromising the gear.
Thank you
Thank you
