Materials Database 1
pdybeck
599
I had a chance to mess around and start to create a material database that is pertinent to my company, rather than the out of the box one from SolidWorks. Am I missing anything, or can you only input material property values in metric in the new material database? It seems very poor if this is the case. Also, I posted another thread about this, but why is there a limitation of character space for the material name? Try adding a longer material name - you can't put anything in there past the space provided. This is very limited if you have a long material callout like this "STEEL ROUND BAR, 4140 Q & T PER ASTM A434-90a CLASS BD". I have had it suggested that we just abbreviate, but then we have people here guessing at what the abbreviation is, since this name will eventually show up on the drawing via custom file properties. The material database has some promise, but needs some work. What you guys think of it?
Yes this is a limitation at this time. Enhancement Request.
Have you called your VAR to ask this one? That would probably be a question SW should answer. Otherwise - Enhancement Request.
Classification - Steel Rd. Bar
Material name - 4140 Q&T BD
Just and idea. Otherwise, Enhancement Request.
Welcome to new functionality. To improve or change something in SW you need to place Enhancement Requests into All those get counted up and once enough people decide what they want, it gets put into the program.
Scott Baugh, CSWP[machinegun][beaver]
3DVision Technologies
faq731-376
